Deputy1211
Toyota forerunner 2001 2wd
151,547 miles at time of this incident.
Woke up and battery was dead. Got jumped off and drove to walmart to replace battery. No issues with the drive there. Removed battery and took into walmart. They installed a compatible replacement in the next 30 mins.
THen I drove home....only to discover that my shifting seemed off. Like the acceleration was sluggish almost fighting me back. Then when it finally shifts into first gear it gives you quite a jolt (like when a teen driver is learning to apply the brakes and you fly forward a little in your seat). Other than this it seems ok but what is up with the shifting??? Called around and was told to wait till I got past 100 miles as the computer might need to reset/recalibrate,etc. NOw at 136 and still no change. Can get up to the upper speeds 65/70 and no rpm problems, temp is good, starts right up now etc.
WTH?? SUggestions, thoughts, theories, are all welcome.
DOn't want to take this into a mechanic not knowing a thing or they'll certainly take me for all they can.
