OEM Accessory Ft Bumper Skid
inscarguy
Member
i just picked up one of those accessory bumper skids. are the brackets the same from 03-05 and from 06-09 or they all the same?
I don't know if they are the same, but they can't be that different.
I've attached the following pdf to help you with the install. It also identifies the bill of materials. Fasteners are a bit complicated because you'll need a metric Riv Nut to secure the bracket to the frame.
http://www.toyotapart.com/PT212-89070.pdf
I bought all of the fasteners at McMaster Carr.
where did you find the skid plate to purchase? I know it is not that heavy duty but will do what I need and that is keep bushes out of the radiator.
found it on here. thanks to a fellow member. already put it on. ill take pics of all the mods i have done when it stops raining.
You'll be disappointed with any functionality. It ends right behind the bumper and leaves the radiator completely exposed.
Consider it for aesthetics only :artist2:
looks like someone beat me to the McMaster Carr recommendation. And for the op, the brackets are the same for all 4th gens I believe..
BillM777
