OEM Differential Bolt size needed to remove Diff Drop
comtn4x4
Senior Member
Can anyone help out with a part number or a size for the original bolt size for the differential? I'm removing my diff drop and don't have the original bolt.
Thanks in advance
Thanks in advance
I can't be of any help about the bolt size, sry. I'm about do to 6112/5100 and was wondering if a diff drop would be needed. Why are you going back to stock? When is a drop needed? If you have advice on when the UCAs should be replaced as well? In regards to clearance when lifting, not necessarily off-road performance. Thanks
You can always buy a set of cheap calipers from Harbor Freight and measure the bolt. I imagine it's something like an M12x1.25, as for length, I'm not sure. I'd just subtract the thickness of the diff drop spacer from the length of the bolt and go from there.
albertpeter156
