OEM Roof Rack and Crossbars
fathousecat_
Hello,
I am wondering which cargo boxes (yakima,thule,etc) fit the OEM bars? Also, can anyone give insight to any rooftop baskets? I would be looking for a half basket since the other half would be taken up by the cargo box.
Cheers.
If you are going to put any substantial weight (150ish), I would strongly suggest a set of aftermarket crossbars from a reputable mfr. or fabricator.
The OEM bars are rather "bouncy" when loaded up. And the usable real estate is barely enough for a typical 16 cu. ft. cargo box - let alone a basket next to it.
To add to this, the OEM cross bar ends are plastic and can break with significant weight.
A reasonably loaded roof box should be no problem though.
Basically most roof boxes will fit just fine. I have a very long (and now pretty old) Yakima space booster that doesn't allow the hatch to open, but most of the modern boxes will work just fine unless maybe you are going HUGE in size.
-Charlie
I have way overloaded the factory cross bars esp when you consider they are plastic. The other slight issue is that with a basket it sits up higher. I plan to make my own cross bars this spring as my current 4r did not come with the cross bars and local wreckers want 50 for them.
these might help me or others thinking of building thier own cross bars or anchors for racks
Roof Track Anchor Plate — Sherpa Equipment Company
Do as I say, not as I do, eh?
(my 4Runner, HD trip - slow side streets only!)
-Charlie
Add extra OEM cross bars, I run 4 of them and I think you can fit 5or6:). Go to the wreckers and keep the end caps you take off, I have found they need to be warmed up before removing and installing or the tab breaks being this old and the conditions they see.
Good idea for distributing the weight, but if the cargo box mounting locations are recessed into the box's base,
the extra bars may prevent the clamps from correctly grabbing the intended bars.
This will also do nothing to increase space for additional accessories.
Running a narrow basket (24"ish a la Skinny Warrior) and a full width cargo box
will almost certainly require a near 60" wide set of crossbars.
did you make those, at one time I thought you said you were gonna make your own.
Yes, those are mine. I've been testing them out since summer on my 3rd Gen. I'm going to be releasing a 3rd Gen & 5th Gen crossbar kit in a couple weeks. The 4th Gen will be right behind those.
Mike
I made my own crossbars from some flatbar, and 1"×2" rectangular tube. Super simple, super strong, and probably a little more heavy then needed. When wheeling it holds the big gas can, firewood, hi-lift, and traction boards. After trips to home depot it has held maybe 200 lbs of wood. It mounts using the OEM stainless inserts in the OEM rails.
pictures ?
I've only used my roof rack for mattress hauling 2 times but i'm sure its not very strong especially since its 20 year factory plastic. Upgrading to metal cross bars would be great at least.
Everyone,
Thank you for the feedback. I had come across the stock cross bars and system in general is not viable. However, I am going to try it as I have found the Thule Sport cargo box fits the bars. I am only storing clothing in their and some bags. It will not exceed 25lbs. Now, if I plan on changing my plans I will for sure switch them out. I hope everyone has a nice day.
Do you know whats those are called? Because I'm having a dickens of a time trying to find the.
Thanks,
You won't be able to find them since this is my own design. I will have them for sale in a crossbar kit in a couple of weeks, and you'll also be able to purchase just the feet if needed.
Mike
Mike
Interested depending on cost of kit. Are you planning to start a thread so we can get in line for a kit?
I'll get something posted here once I have everything in hand, and might start a Group Buy too. Pricing should be pretty good for what you get.
Mike
I'd love to have sturdy metal crossbars instead of the stock plastic ones. Do the pictured feet insert to the stock rail slots?
Mike
anything with these yet ? Might just have to make up something as I need my rack soon
BillM777
