OEM shocks or not?
RHINOSAUR
Hello,
Have not been here in a while but glad to be back...:)
I noticed that my 2 rear shocks on my 2010 SR5 have begun to leak a bit...they are the standard OEM that came with the vehicle (we bought the vehicle brand new)
I do go off-roading and i make it a point to do so ...so on average maybe 3-4 times a year...on some pretty cools trails in the SoCal area and actually used the 4 lo and atrac etc .. however i don't quite have a budget to customize like harper 7 but I would like to little by little ...maybe do some minor mods at the right time.....I'm pretty much stock 100% as is
so the question to all the experts is, if I HAVE to replace the rear shocks...should I get the OEM ones or should I get something maybe better suited for off roading ...that my not brake the bank...say max 2x the cost of the OEM but that may be worth it...
many thanks
cheers and hi to all!
5100's are a good place to start and since the OEM Tokico shocks are about a 40.00 shock, you can definitely do better since you do some off roading.
the 5100 seem great
i looked at the thread on the lift kits..very cool,
But now I am slightly confused...
do i need additional hardware to the bare pair of shocks.....or can i simply buy the pair of 5100's and replace one to one with the OEM without additional parts?
Buy 2 for the rear, install them yourself. Nothing else needed. Only one nut on top and 1bolt on the bottom. You will feel the differance in better control off-road. Do the front later as budget allows and sett to 0.85 or 1.75 to level.
If the rears need replacement, then how far behind are the fronts? I am of the opinion that all 4 shocks s/b replaced with those with same attributes. New on back with old up front makes no sense to me.
Billys are an excellent value-compromise between cost, simplicity of installation and improved ride.
Definitely go with at least Bilstein 5100's since you off-road. Supposed to add an inch or two of down-flex.
Bilstein 5100 Rear shocks for FJ/4Runner
Extremely easy to self-install:
- Jack up on the frame, add jack stands.
- Remove rear tire
- Two bolts off and on.
- Replace rear tire.
- Do same on other side and done.
As others have said, I also recommend swapping out the front shocks at the same time, but it isn't absolutely necessary if you lack the funds right now. Fronts are harder to self-install because they are coilovers. Unless you buy a full coilover assembly (shock + spring) pre-set to your desired height you have to rent or borrow special equipment to compress the spring. Plus just getting the front suspension apart to remove the assembly can be a chore (I just did it a few weeks ago for a spacer lift). Plus the added cost of the required alignment. Doing front + rear together will be at least 3x-4x the cost of self-installing just the rears.
Just be aware that if the rears are gone, the fronts may go next month... and if you buy all four shocks as a package you may get a discount.
[Edited: forgot about removing rear tire :twitch:]
Admittedly, my 4rnnr is stock as well...im too busy tinerking with my motorcycles...
but as a point of reference...if something is used up, or breaks...it is the EXACT time to upgrade...period-end of story.
as has been said, go find a solid replacement upgrade part that you can afford, slide those in...and live the better life...then when its time, and money affords, upgrade the front.
:bigok:
Where in SoCal are you? I have a pair of 2015 OEM rears with 1k on them if you want a decent deal and OEM is the route you want to go.
Regular ol' shocks
How about recommendations for just regular shocks for my '97 4Runner. I don't do off roading, just Los Angeles driving. Looking for good, reliable rear shocks but don't need height adjustment or anything fancy. I'd also like to avoid the OEM shocks as I think even for city driving, I could do better. Any thoughts about KYB shocks for the rear? Thanks for any help.
FRONTS
https://www.amazon.com/Monroe-71371-OESpectrum-Reflex-Strut/dp/B0012X0ILU
REARS
https://www.amazon.com/Monroe-37270-OESpectrum-Shock-Absorber/dp/B009AA5JW0
REBATE
http://www.monroe.com/downloads/promotions/2017-Monroe-Holiday-Consumer-Promotion-US.pdf
I've submitted a rebate in the past for another vehicle and received it within the timeframe noted. I didn't scour the web thoroughly for the best price. I'd give rockauto a quick search. Rockauto may still be cheaper even if they charge shipping. They alwys have a 5% discount coupon code floating around the web.
