I recently installed (with some help from the vendor) Off Grid's (offgrid4x4.com's) second battery kit for 5th gen 4runners. This kit uses the Blue Seas ML-ACR solenoid which automatically connects the batteries when it detects a charging voltage (above 13.5V I think) and disconnects the batteries when the voltage drops below 12.75V, if memory serves.
Here is what the battery kit looks like installed.
The first battery remains in the original battery position and continues to power all the stock electronics and the starter. It is also connected directly to the alternator. The second battery sits over the passenger side fender by the firewall, seen in the upper left in the photo.
For my installation, I used the following:
I'm planning to leave the second battery as a backup startup battery and power any new accessories from the primary battery. This way it is much harder to end up with a 2 dead battery scenario, and redundancy was my main goal with this modification.
This wiring does have some downsides. First, you can only get 200 amps sustained from the second battery because it has a 200 amp slow burn fuse. With the right wiring, it should be possible to have a bigger fuse and I'll probably do that at some point. Since the fuse is slow burn though, you can still get much more amperage for short bursts (like starting). I plan to keep a few spare fuses and a wrench in the truck just in case though. I wonder if the slow burn is slow enough for periodic 400amp winching...
Second, the ECU controls the output voltage by briefly disconnecting the alternator and sampling the battery voltage. If you've been camping and have discharged the main battery a lot, its voltage will be low and you want the alternator to supply maximum voltage and current to rapidly charge the battery. However, the ML-ACR will have connected the two batteries together and the ECU will sense the higher voltage of the second battery and reduce the voltage, slowing the charging of the discharged battery.
In the following posts in this thread, I'll show what I did, with some help, to install the kit. As a car mod noob there were a few things I needed help with that should have been obvious in hindsight, and I'll point that out too.
- HKB alternator voltage boosting fuse (for better charging of AGM batteries at up to 14.6V instead of 13.8V max from the alternator)
- Off-grid 5th gen second battery kit
- X2 24F Battery from batteries plus in the OEM battery location
- X2 35 series battery in the second battery location
- Extra long tie down rods for the factory battery (supplied by Off Grid on request)
