Offecenter rear axle?..
listo
Member
Just had my new FN fx pros installed. New tires are KO2'in stock size.
While walking around the 4runner today I noticed the rear axle is pulled to the right about 1". Stock 13' SR5 with zero lift. No accidents at all. Most likely always like this but with the wider wheels it's more noticeable
Any thought. Adjustable rear track bar?.
Should be centered stock.. but yea you can center it with an adjustable track bar at ride height. it will still move a little when loaded...Just the way it works.
I would not worry about it. I bet if you go load the back with bricks to level it.. The axle will be on center. ;-)
utkrstam
