Jumpkix
Keep in mind that these AR platforms were designed around military use. Most M-4's and M-16's are used in a dirty environment where a dust cover is important to keep debris out and help prevent jams. For the average person a dust cover may not be necessary since their rifles see maybe 100-500 rounds a month at a range and is cleaned right after. Most times at the range there isn't a whole lot of dust, dirt or debris flying around to worry about.
Edit: The forward assist in my mind is a useless part. I have used the M-16's and M-4's in just about every variant that they come in through the military. I have rarely had any jams and the jams that I have had were easily cleared. The military teaches you a method called S.P.O.R.T.S. to clear a jam. Slap the mag up to make sure it's seated. Pull the charging handle back. Observe that a round or shell comes out of the ejection port. Release the charging handle. Tap the forward assist to ensure the bolt is fully seated. Squeeze the trigger to continue firing. Any time I clear a jam I do those steps but skip the forward assist part. I have never once used the forward assist in the tens of thousands of rounds I have put through an M-4 and have never had any issues with not using it.
I've always heard this same procedure referred to as "Tap, rack, bang." Appreciate the good info.
