OffRoadWarehouse & ICON Vehicile Dynamics 2010-UP 4Runner
OffRoadWarehouse & ICON Vehicle Dynamics 2010-UP 4Runner Buyers Guide
OffRoadWarehouse & ICON Vehicle Dynamics offers Full Suspension kits for 1996-Current Toyota 4Runners
Designed in several stages that provide just the right amount of boost for your ride, these world-class lift kits are custom-engineered to deliver your Toyota 4Runner giving you the ultimate off-road experience.
All ICON Kits are constructed to outlast your vehicle with durable CAD-plated coilover shock bodies, 6061 aircraft-grade aluminum CNC-machined components, exceptional cooling properties and ICON-engineered Eibach springs.
Each ICON Lift Kit comes complete with everything you need to install so you’re not left piecing together parts on your own. Feel at ease with the Lifetime Warranty on ICON components and a 1-year warranty on shocks.
Every Stage of ICON Kit Form is unique and Stage 1 is Entry Level. You CAN Build up to Stage 7 is so desired by Adding or swapping out Parts.
GREEN TEXT Denotes addition/upgrades to previous Stage forms.
Wheel & Tire Fitment Info:
OEM Wheels & Tires: Yes
Aftermarket Wheels: 16" - 18" w/ up to 5" Backspace 20" + w/ up to 5.250 Backspace (pending wheel make)
Aftermarket Tires: 33" Tall Tires Larger Tires May Fit but Fender Trimming and Modifications will be Required.
Icon Stage 1 0-3.5'' Suspension System for 10-Up Toyota FJ Cruiser/4Runner #K53061
System Components:
58646 (QTY - 1) - Standard Travel Adjustable Coil-over Shock Kit
52700 (QTY - 1) - 2" Lift Rear Coil-spring Kit
56505 (QTY - 2) - ICON V.S. 2.0 Aluminum Series Rear Mono-tube Shocks w/ Internal Reservoir
• KDSS Equipped vehicles require #54200 Rear Adjustable Track Bar
198000 (QTY - 1) - ICON 2 pin spanner wrench​
Stage 1 comes with Standard Travel Coilovers, No Additional Travel is gained if Upper Control is Added unless you rebuild your coilovers.
Please upgrade to Stage 2+ for extended travel coilovers.​
Icon Stage 2 0-3.5'' Suspension System for 10-Up Toyota FJ Cruiser/4Runner
Choose Tubular or Billet UCA
System Components:
58647 (QTY - 1) - Extended Travel Adjustable Coil-over Shock Kit
58451 (QTY - 1) - Tubular Upper Control Arm Kit OR #58551 Billet Uniball UCA
ORW Notes: Stage 2 is a Popular and Best Upgrade you can do for your 4Runner/FJ. Comes with the Extended Travel Coilovers and choose between the Tubular or Billet UCA.​
Icon Stage 3 0-3.5'' Suspension System for 10-Up Toyota FJ Cruiser/4Runner
Choose Tubular or Billet UCA​
System Components:​
58451 (QTY - 1) - Tubular Uniball Upper Control Arm Kit or Billet UCA #58551
54000 (QTY - 1) - Billet Aluminum Lower Rear Trailing Arm Kit
ORW Notes:
Stage 3 comes ADDs #54000 Billet Trailing Arm Kit which are a great upgrade for the weak factory lower links. Billet is STRONG and Lightweight and have been engineered to increase off-road ride quality. A Nylon rock slider is incorporated into the design of the arm to prevent any hang ups on the trail.​
Icon Stage 4 0-3.5'' Suspension System for 10-Up Toyota FJ Cruiser/4Runner
System Components:
58451 (QTY - 1) - Tubular Uniball Upper Control Arm Kit OR #58551 Billet UCA
57810 (QTY - 2) - ICON V.S. 2.5 Series Remote Reservoir Rear Shocks
ORW Notes: Stage 4 comes upgrades the rear shocks to #57810 ICON Vehicle Specific (V.S.) 2.5 Series Shocks with RR (remote reservoirs) good for 0-3" rear lift. These are BUILT to give your 4Runner/FJ outstanding performance off-road and a smooth ride on the street.​
Icon Stage 5 0-3.5'' Suspension System for 10-Up Toyota FJ Cruiser/4Runner
System Components:
58747 (QTY - 1) - Extended Travel Remote Reservoir Adjustable Coil-over Shock Kit
ORW Notes: Stage 5 gives you the same as the Stage 4 but upgrades the Front Coilover to #58747 Extended Travel with Remote Reservoir.​
Icon Stage 6 0-3.5'' Suspension System for 10-Up Toyota FJ Cruiser/4Runner
System Components:​
System Components:​
54100 (QTY - 1) - Billet Aluminum Upper Rear Trailing Arm Kit
54200 (QTY - 1) - Rear Adjustable Pan-Rod Bar Kit
ORW Notes: ICON Upper & Lower Billet Arms are now included with this kit. These links are LIGHT and STONG! They feature greaseable polyurethane bushings for a smooth ride with minimal deflection. Also in this Stage 6 kit you will benefit from the ICON rear adjustable track bar, When you track alignment is off center it can cause premature tire wear and have as precise articulation. This track bar can be adjusted on the truck without having to take it on and off.​
Icon Stage 7 0-3.5'' Suspension System for 10-Up Toyota FJ Cruiser/4Runner
System Components:
58747C (QTY - 1) - Extended Travel Remote Reservoir Adjustable Coil-over Shock Kit w/ CDCV
57810C (QTY - 2) - ICON V.S. 2.5 Series Remote Reservoir Rear Shocks w/ CDCV
ORW Notes: The ICON CDC Valve upgrade is included for those desiring an easy way to tune the ride externally with 10 adjustment settings from soft to hard. When paired with ICON rear 2.0 Aluminum Series or 2.5 Series shocks, vehicle control will be balanced front to rear resulting in the best overall driving experience for your 4Runner/FJ. Now that you have the Lower Trailing Arms it's time to upgrade the UPPERS #54100 ICON Billet Aluminum Upper Links are a GREAT replacement for weak Factory Upper links. These links are LIGHT and STONG! They feature greaseable polyurethane bushings for a smooth ride with minimal deflection. Also in this Stage 6 kit you will benefit from the ICON rear adjustable track bar, When you track alignment is off center it can cause premature tire wear and have as precise articulation. This track bar can be adjusted on the truck without having to take it on and off.​
Shopping with ORW makes your shopping EASY. We can ADD/Remove individual items as needed. Off Road Warehouse has ALL the ICON parts on our site or call us 800-341-7757
PM or [email protected]
for a quick response.
Upgrade Options:
56100 (QTY - 1) - ICON Rear shock shin guards
52800 (QTY - 1) - ICON Overland Series dual rate 3" lift rear coil springs
56104 (QTY - 1) - Rear hydraulic bumpstop kit
More parts will be ADDED to this thread. Please stay tuned!!​
Thank you for your orders!! We appreciate your support! All tracking numbers have been updated. If you are looking for an ICON suspension kit please let us know. We will not be undersold on pricing!! ​
seltzernator
