Oh No. I just bought the car and then CEL + + +
Michael M
Stopped at the gas station to top the tank off and check the dip stick. Drove on the highway on cruise control set at 65-70mph. 15 minutes into it I look down and get a terrible sinking feeling in my stomach. I bought the 2006 V6 2 days ago. Now the CEL, VSC OFF, VSC TRAC and slippery sliding truck light are all on.
Guys. Do I go back to the BMW dealer that sold it to me and be like "wtf"? Do I take it to a Toyota shop? Or is this something I can trouble shoot myself.
Please tell me this is no biggie with Toyotas. I just left the very expensive world of repairing Audi's.
So bummed. Scared I just bought into a bad deal…..
help.
Make sure your gas cap is tight. Same thing happened to me a week after I picked up my used '07 T4R. Emission control computer doesn't like a loose gas cap. ;-)
Stop at any Autozone or auto parts store and they will check the code(s) and clear them for free...
-Dan
help.
Are you 100% sure the gas cap was nice and tight?
Alright, so, I realize now that after filling up, I never heard any clicks when closing the cap. Now I made that sucker click like fifteen times. I must admit that it takes a lot more effort than my last car.
Realizing the car might need 5-10 minutes of running time to sort itself out, I'm gonna go pick up my buddy from the airport and hopefully see it clear.
If it doesn't, I'll stop by a parts store and ask them to scan/clear.
Sorry for freaking out. I read an excellent explanation written by BlackWorksInc HERE and legitimately freaked my shit when I read the words :AK47:transmission issue.
Thanks for the quick response guys. I'll report back with hopefully some good news soon.
Cheers!
All warning lights cleared after an evening of driving! Thanks for your help and quick responses guys. All is well!
Funny I had the same thing the day after I bought mine. My cap was actually bad though, did not seal shit or click at all. Trip to dealer for OEM cap fixed it right up, lol....
+1 for the gas cap, same day I bought mine.
Scary feeling, but much relief when I found out it was
The gas cap.
That's really odd. I picked up my '07 Sport Edition last July, drove it like 40 miles home from a Toyota dealer and it coded just as I pulled in the driveway. I walked right inside my house, checked on the forum and someone had mentioned a gas cap issue.
I immediately drove to an Autozone, picked up a new cap and had them clear the codes. No more CEL's for me since that day.
The odd part of this is, why would a Toyota dealer not fix a $10 problem before you take delivery of the truck? I know mine must have been coding under their ownership, so instead they clear the code and pass the cost right to us. It's kind of rhetorical, but :wtf:
No need to make gas cap click that many times. Once or twice if cap is in good condition. Don't want to wear it out.
I never understood why Toyota would compromise your saftey by deactivating stability and traction control for a gas cap. Pretty dumb.
Cheers!
Sorry to freak you out, it was meant as a broad stroke of what it could be. The important point in that thread I made was to get the DTCs (Diagnostic Trouble Codes) first and foremost, that way you can see what the vehicle thinks is the issue; from there you can proceed to freak out. :) Its more about determining WHY the light is on, rather than stressing yourself out about "maybes" until you find out what it really is; that and most people always come on the forum going "my light is on, what's wrong with my 4Runner!" To which my typical thought is, "so... can you be more vague? :P "
Right? You'd think a CEL would suffice.
The reason they did this is because OBDII (On-Board Diagnostics Generation 2) regulations dictate that an MIL (Malfunction Indicator Lamp, aka. "Check Engine Light") is to be set when an emissions related DTC is set. Typically any DTC that has to do with the powertrain will set a OBDII DTC (some transmission problems will set an OBDII DTC as well, but those are usually generic "hey I have a code stored in my factory module, use the factory scantool to find out what it is" codes), the reason this is important to realize is that all modern VSC (Vehicle Stability) and Traction Control systems work by modulating both the ABS system and de-throttling/reducing engine output to maintain stability; what this means is that the vehicle needs to know that the ABS and Powertrain controls systems are functioning properly to make VSC/TRAC function as designed. Since only a very small selection of OBDII DTCs (specifically the small range of EVAP DTCs) don't have anything to do with the engine performance some manufacturers erred on the side of caution and programmed their vehicles to respond to any OBDII DTC as an indication that the Powertrain is no longer reliable/safe to rely on for data input/output and thus disables the VSC/TRAC systems so that it will not cause improper performance that could damage the vehicle and/or driver.
For example: the computer doesn't know what DTC is set, it just knows that an OBDII DTC has been set. It could be a P2119-Throttle Body Control Malfunction in which the throttle body may have failed completely or a P0455-Gross EVAP Leak Detected (the usual "gas cap code") which will technically set the MIL on from an OBDII standard. Either way, the system is programmed to see any OBDII "generic" DTC as a possible powertrain failure and thus suspend VSC & Trac systems (you'll notice ABS should still function unless that system has also been compromised, since it does not rely on powertrain input/output values.)
I know that's a bit technical, but I hope that helps answer your questions @SolRays & [MENTION=108365]Michael M[/MENTION]
Does anyone know what the exact code is that is generated with a loose or bad gas cap?
Usually the DTCs set when a gas cap is loose is a P0455- Gross EVAP leak detected. But also any of the following may set in conjunction; P0440- EVAP System Malfunction, P0441- Incorrect EVAP Purge Flow, P0442- Leak Detected (.040" Leak), P0456- Small EVAP Leak Detected (.020" Leak)
It usually depends on when the EVAP monitor failed during the test, you're rarely going to have a .040" or .020" leak DTC set because the test will see the "Gross EVAP Leak" (far above a .040" leak) before it gets to the point of testing for itty bitty leaks (but a borderline failing gas cap could cause them), it may set the Purge Flow DTC because it doesn't detect that the system is properly sealed and purging/venting (which it would do normally if the system was sealed off, i.e. cap tight), and the P0440 is a generic EVAP Malfunction DTC that sometimes comes on.
utkrstam
