Oil Change Advice
Online it is, my Walmart sux.
Follow up, how much oil does it take? (I didn’t get a manual with mine)
V6 is 5.5 quarts with filter change but I sometimes find myself adding a little bit more to have it at the correct level. Start the truck after adding 5.5 qts and let it run for 1-2 mins so the oil gets circulated and check the level again. I don't have the I4 but I read it's 4.7 qts with filter.
Awesome thank you so much!
I have the V6 also. I will follow that guideline.
Anyone have the part number for the OEM Toyota Oil filter (non cartridge) websites all say “it’s a fit” for like 4 different Toyota filters.
I use Pennzoil Platinum 5W30 and a NAPA Platinum filter at 10,000 mile intervals. If you use conventional 5W30 and a Wix, NAPA gold (same thing) Mann, Hengst, or Toyota filter at 5000 mile intervals you'll be fine,
Technically the OEM p/n is 90915-YZZD1 but a myriad of filters will fit, both OEM and aftermarket. I use a D3 filter myself, which were for Tundras if I'm not mistaken. If you just tell the parts store counter your car and engine they'll do the legwork for you.
2001ATL
