2005 V6 SR5, 115k miles. DIY oil changed yesterday afternoon.
when i removed the drain plug, it was already fairly loose. never noticed engine oil leak before. the drain pan collected about 4.5 to 5 quart, very rough estimate. i know the capacity is about 5.5 qt.
so i wanted to make sure this time i really tightened it to spec, 30 ft lb. Got the new torque wrench out, it's this model:
Amazon.com: Mountain 16250 1/2-inch Drive Torque Wrench - 25-250 ft/lbs: Home Improvement
it might be too beefy for this application as 30 is about as low torque as it goes. i double checked i'd the mark on the shaft at the lowest 25 ftlb, then 5 at rotation dial. as i started fastening the drain plug, the new gasket broke. so as i removed it to put the old one back on, i realized it wasn't that tight as all. really confused. i've never used torque wrench before but i expect the wrench to make clicking sound and just spins in place once preset torque is reached. Or, maybe the gasket (crush washer) is defective? I bought it from Toyota Dealership Service a couple months back. I inspected the broken pieces, it's all plastic - that's what it seemed to me.
We'd some rain over night and i saw some oil slick on my driveway. Really hoping it's just the spills from oil change, not a leak from the drain plug. It makes it hard to inspect in this wet weather. I'll take a look at dipstick tonight before driving home.
