Oil drain plug plastic cover
twfran
I need a replacement cover for the oil drain plug access on my 2007 V6 SE. This is a flimsy plastic piece with clips to hold it in the oval cut-out. Any pointers on either a better replacement or where to get this piece? Probably only a dealer item, and I am not looking forward to how much they may want for a new one...
And, yes, the loss of this piece did involve mud, gravel and smiles!
I think almost everyone on here has lost this piece.
It's not essential so don't waste your money to replace it. You'll just end up losing it again.
twfran said:
I'll trade you my driveline clunk for it! :D
Lube your rear drive shaft slip yoke instead.
Lots of threads and controvery on the forum to search for this concern.
<<<< said:
That plastic lid is only $ 16.00 (at least at my local Toyota).
Gulp only $16? I lost mine - looking to make a replacement out of 50 cents worth of polished 1/16 aluminum diamond plate. I can't see that being but a $3 piece even if it has a Yota logo on it. Geeze. Lost mine on highway commute so no good story there to justify $16.
I'm thinking along the same lines as wolfgang. Probably will make a metal cover (same gauge as the rock shield down there) and attach it with some kind of quick-release screw or clip. Should keep some dirt and debris from getting in there...
