Oil filter wrench for 2002 4Runner?
Will this wrench work for a 2002 4Runner? I looked at it the other day and it seems easy to reach through the wheel well but just akward to grip it and turn, I can't use a band wrench.
http://www.amazon.com/Worlds-Best-Universal-Filter-Wrench/dp/B000M96RVA/ref=sr_1_2?ie=UTF8&s=automotive&qid=1251398078&sr=8-2
I have never changed the oil on a '02 4Runner but I did sleep in a Holiday Inn Express last night.... :lmao:
Seriously, I have a similar design filter wrench and love it, I use it all of the time on other vehicles. My '07 V6 has super easy filter access so I don't use it on my T4R...
:cheers:
:cheers:
LOL,
It looks like it will be pretty easy to reach but just takes the right tool I guess.
should be the same as my 01. I jusr use a standard end cap for a socket wrench and bought a 3 foot extension for a few bucks at harbor Freight.
I turn the whee and can reach all the way in without troublre
Ghostrider reply on oil change
Did you have to remove the fender liner and clips first ??
I have an 02. I changed the oil myself for the first time, but was changing the front diff at the same time, so I had my skid plate off and was able to reach the filter easier from underside. But next time, I think I wil invest in one of those with the extension. You are right that a band wrench will not work reaching through the side, I tried that first.
I had a 2000 Tacoma with the same engine. Yes, you could reach through the wheel well, but then you're left with an oily mess on the skid plate. I bit the bullet and removed the skid plate every time.
On my 01 their isn't a need to remove the fender clips. I can reach thru the gap. I do remove the skid plate to prevent an oily mess.
