Oil filter wrench for 4th gen V8
4RNR-LOVN
For those that have changed the oil and filter on the V8 you probably know how hard it is to find a darn wrench that fits the filter properly. I've tried to find a fluted style that fits a 3/8 or 1/2 ratchet the previous 3 times I've changed my oil with no luck. Well, I guess the fourth time was the charm. A local dealer that I got my filter from just happened to get in a set of 74mm (14 fluted) wrench that works perfectly (Larry Miller Toyota in Glendale, AZ).
Karl
I pick up a wrench at PepBoys. I walked in with my Toyota (90915-YYZD3) filter and fitted it to one that mated. I cannot insert the ratchet extension completely in the square hole however. Just half way in, or else the extension punches in thru the wrench & hits the filter.
ToyotaDoodz said:
Thanks Karl, are they on the Internet?
Hey ToyotaDoodz. They are on the internet at Larrymiller-Toyota.com. The part # of the wrench is 30359-91020 for $5.49. The best money I've spent on the 4Runner recently, that's for sure.
I like the new BFG's by the way, very nice!
Karl
Sure, but that case could be made for anything. For me, it's hard to tighten by hand with oil residue keeping me from getting a good grip on the filter so I worry about not having it on good enough. If you use the wrench, common sense, and only tighten 1/2-3/4 of a turn after the filter makes contact then you should be fine.
On vehicles that I have owned, I put the oil filter on as hard as I can tighten it with my left hand (my weak hand), that way I can always remove it with my right hand. However, due to the close fit on the V8’s, I can not get it on tight enough to stop it from leaking, so I tighten it just a tad bit with a wrench.
