oil leaks
4ballin
i too have a pretty decent oil leak.was there common oil leaks in these things?i have the 98' 3.4 limited by the way.i figure the valve cover gaskets at least and probably cam seals.how hard is it to change these things?is there any info out there on the fixes?
I dont think its all too common to have "leaks" but drips maybe. but with age comes leaks/drips whatever you want to call it, for the most part. I myself had a valve cover leak, all solved now with new gaskets, some just need the bolts tightened a tiny bit.
