OK I want A supercharger for the 3.0....
Status
Not open for further replies.
Kingdome4runner
DOes anyone know where I can find one I've looked but none has a super charger for the 3.0 v6 any help would be great.
The engine is the 3vze thanks
Sorry guys
I think we are just screwed,because I haven't found one either. There might be more luck with a turbo setup. I'm trying to find something.
Kingdome4runner said:
The 3.4 swap would end up costing way too much like 6 grand but i'll look into that turbo and post what I find
6 grand? Find a wrecked doner truck....2-4 grand depending on miles.
The trany bolts to the bell housing, the motor mounts are the same, you can reuse your old raidator, and most other parts come from the doner truck. I dont think it would be a hard swap at all. It should be a reasonable swap if you do the work on your own.
Ya, your pritty much stuck with the 3.slow just the way it is. Not worth putting much money in.
Coop
The 3.0 is known for head gasket issues. What do you think the added pressure from a turbo is going to do?
It's a POS engine, spending $$ on a turbo would be unwise.
The money would be much better off spent putting in a 3.4.
3. slow
i've hear alot of response about the 3.slow, coming from a person w 22r's, put the right gear ratio and go from 3.slow to 3.GO.
Fully against pumping money into a 3.0 for any reason. The 3.4 swap is not really that difficult, and if you've got smarts, you can get it done without too much out of pocket. I've watched a couple be done fairly quickly.
Plus, if you s/c the 3.4, there's some good power to be had.
I'd say any 3.0 owner wanting more power needs to regear. If that's already done, it's time to get that paperweight out of the engine bay. Same goes for a 22re, to a lesser degree.
There's no point in doing anything to the 3.0L It's a decent engine stock, but once you start messing with things it just doesn't hold up as well. There's no supercharger that bolts on, though some have done a turbo on it. But like Fourwd1 said it's not worth much. Saving up and doing a 3.4L swap will be your best option and best bang for your buck.
i am new to the 3.0 wife had a couple of 3rd gen 3.4 but i never did drive them much
my new shop vehical is a 92 3.0 430 gears and a 5 speed that i just installed a jdm engine in. I have been driveing it for a couple of weeks and i am impressed with the power but a set of headers would make sense to get rid of the stock cross over. this thing would eat any 22re i own
Usually a shop truck is around for 6 to 12 months before it is sold but i may keep this one for awhile
couple grand for a super or turbo charger on a 3.0. blow it up and see how much better you would be off with a proper supercharged motor. a 3.4.
Status
2001ATL
