Ok, last lift-based question I'm going to ask
keylay31
Upon lifting your t4r with a 2/1 cornfed lift, i have two concerns:
1) with the lift, the tires rotate down, does this result in the tires being at a slight angle and therefore uneven wear?
2) does this same rotation cause stress on any part of the vehicle? (i know with some types of lifts, you might need extenders in certain places (i.e. drive shaft), but i don't foresee a problem here)
1. Once you do a suspension lift, get an alignment done (after a few hundred miles under your belt). This will resolve any issues and concerns regarding uneven wear on your tires.
2. no worries here
