old man emu suspension
surfcorpus
I just put in an all new suspension from old man emu, spring, shock, torsions bars, on my 89 t4r, overall very happy with it but now the rear ride a bit higher than the front, I was thinking of removing the smaller leaf of the spring, has anybody done that before, or any recommendations ?
Thank's
how much of a difference is it? If its a small difference the easiest would be to crank up the torsion bars to match but you will get a stiffer ride. For larger difference (like 1.5"+) ball joint spacers would be the way to go. That is unless you dont want it lifted any more i guess you could take a leaf out.
Thank's
:worthless
Had to do it.
009
[/IMG]
I am having the same thought as you on my 87 with OME rear 2" lift springs. My thought is since I don't haul more than 100 lbs of gear on my trips I might as well take out the overload spring and see what happens. But you can go first, be my guest!
