Old topic, New guy...??? LED conversion
Supertrooper4
Hey guys so yes finally im going to do the LED`s. Got a question...(and im not to familiar with the right terms) whats the right "bulb" LED size thingy for the front 2 over head lights by the sunroof switch???
are you talking about the map lights, like these????
004-4.jpg~original
if so i think there all the same for all years but you may want to look into it, Never mind i just saw you have 02 so yes they are BA9's you can get 2 at VLEDs for 8 bucks these are the ones im running and they do well for light
2501.jpg~original
Scratch that last comment, i looked at the site and i found the blue ones, now whats the difference between when it says blue HID LEDs and just blue LED
hmmmm i have no clue, its probably just a brighter light, dang blue would look pretty sick! post pics when you get them one sec i might be able to get you a dsicount code
damn i already orderd them bro but thanks ill use it when i buy the rest for the dash....now thats another question, oh and i already did the blue for the middle and rear hatch light illl try to post pics
ive got a few that expire today so im not sure if they will still work or not but here they are
5% off a $20 purchase 5OFF20
10% off on 50 10OFF50
and 20% of a $100 20Off100
they'll probably update it soon but you can get all the codes if you add them on facebook
edit: dang! too late haha now did you get the list of bulbs that i sent you for your dash?
here ya go, these are from superbrightleds.com
---------- PRODUCT INFORMATION ----------
Qty | Product / Options | Price (each) |
2 | NEOx High Power LED Instrument bulb | $ 2.29 |
White NEOx-WHP 3mm NEO3-xHP
(rear window, ECT defrost button)
3 | 24-xHP Wedge Base LED bulb | $ 2.49 |
White 24-WHP
(Gauges)
1 | 74-x Wedge Base LED bulb | $ 1.19 |
UV-BlackLight 74-UV
(Keyring, shifter or cig lighter, glove box)
1 | 74-xHP Wedge Base LED Bulb | $ 2.49 |
White 74-WHP
(Keyring or shifter or sig lighter, or glove box)
2 | NEOx LED Instrument bulb | $ 1.29 |
4mm NEO4-x White NEOx-W
Heater, temp, (knobs)
those #74's are kind of pain to get to stick but there the correct bukbs and you just gotta play with them a little bit
Do they make a yellowish color? Close to OEM? If so anyone have them? I will be needing to do my dash soon and might as well do the rest.
im still working on a solution to the hotspots but as for these there not too bad. the red lights in my HVAC aren't from Superbright, its a whole different LED unit... long story bout those lol... but yeah those ones are probably my most noticeable hot spots. all the others seem to be not so bad.
My plans are to line the inside with a reflective tape so the light can spread out more even, and then using some sort of filter in front of the bulb to keep try and frost the light a little but you've probably seen my pics but this is what i have
newlights004-1.jpg~original
Jamacee
The ones i got are a warm white compared to my dome lights. they are basically a pure white that's closer to yellow than it is to blueish white
Jamacee
Cool. I have had MANY a headlight w/ LED for camping and climbing but sometimes you just like the glow of the maglite just a bit better. you know what I mean?
I just prefer the longevity of a LED better. Since I will need to take it apart to replace anyhow I might as well replace it with something that will last.
your's looks great btw. Ever thought about HVAC 1 sided tape? Its like sticky tin foil.
Did u get ur guage lights from VLED? and if so what ones go behind the dash? bc i cant find em on there, and i wanna do blue not white
thanks man, yeah ive seen that stuff, in fact last night my bulb was loose in the HVAC controls so i took it apart and when i put it back together i grabbed some tin foil and taped it all over in there. It spread out the light a lot better then before but im still getting hotspots. i didn't spend a lot of time on it so one of these days im going to do a more professional job
but yeah LED puts out the light a lot different then those maglights, you can never go wrong with a maglight! however i do have this head lamp (for my head) that has a few LEDs in it and the single one is so bright! it beats any flashlight iv'e ever owned.
no i didn't get them from VLEDS, but my next order will be from them for sure The ones in my guages are from autolumination but know that the bulbs there have a tendicy to burn out real quick, a lot of people here have used them and have had them burn out. My guage lights are the only ones that have suprisingly survived for almost 2 years or so snow so im just waiting for the day that they do.
here ya go i think its the complete list with links of the bulbs you need. Now i didn't order from VLEDS so just as long as the bulbs are all classified the same it should all be correct
3 #24's for the guages
2 SMT HIGH POWER BLUE WEDGE BASE LED LIGHT BULBS 24
#74's for the shifter, the glove box and the cig lighter and key ring
2 V-LEDS 3 SMT BLUE WEDGE BASE DASH LIGHT BULBS 37 74
neo wedge T3 you may have to call for the color? but 2 of these for your buttons
http://www.v-leds.com/Interior-LED/Gauge-Cluster-LED/Amber-LED/2-SMT-HIGH-POWER-AMBER-p7688469.html
Neo Wedge T4 you need 3 of these for the HVAC knobs again call for the color
http://www.v-leds.com/Interior-LED/Gauge-Cluster-LED/Green-LED/2-SMT-HIGH-POWER-GREEN-p7688471.html
