OME coil install question
kruegs
Alright, so I had my lift installed a few weeks back (OME 881's up front with OME 890's in the rear). I did some measuring and found that my drivers side leaned a bit compared to the passenger. I assumed initially it was because of the gas tank weight etc. Turns out that the coils may have been installed on the wrong side in the rear... i.e. the one marked "B" is in fact installed on the drivers side, and "A" passenger. As I understand it, A should be on the driver's side as it is a tad longer.
Now, my question... do the front coils ALSO have marks A and B? I cannot find anything on their labels as such. The drivers side trim packer was installed correctly, so I *think* my lean issue is truly just the rear coils needing to be swapped.
Thanks!
Nope, the front coils are identical side to side. It's just the rears that are marked A and B. Swap them, and you'll be good.
