I have an 03 4Runner with an OME front/rear coils spring/shock setup. I ordered a Toytec 3/4" front coil spacer but had no luck installing it. It seemed like all of the droop disappeared once the Toytec spacer was installed- and it was nearly impossible to get the coil/strut assembly back in the strut tower (but it is a breeze w/just the OME). Is this normal? Can the two work together? If so, how.
Thank you
Thank you
