OME full suspension lift question...
jamiemac1
Hey everyone,
I know questions like this have been posed in the forums (and have scoured them relentlessly), but I'm still having a difficult time choosing on a lift.
Here is my situation...
04 T4R Limited w/4.7L V8 - due for suspension/shock replacement anyway. Desired 3" front, 2" rear lift to fit 275/70s
Not looking for hard core off roading like some of you here, but will occasionally roll through some areas when I'm up in North MI. I don't want to go cheap with spacers and end up having things rattling around after a year or two of use. So, I guess I'm looking for the most economical way to make my truck look good, perform on the occasional off road excursion, while at the same time, keeping the ride tight (and reliable).
Any suggestions? I've mainly been looking at the OME full suspension lift, the Ultimate 3" Toytec lift, and even the Radflo... but feel like the last two may be overkill.
I've been lurking in the forums trying to get a few answers, but based on my use (and if I can save a few bucks), I'm thinking the OME is the way to go. Probably go with 275/70s with no major additional weight in the front or back (bike rack at most).
Thanks for any suggestions everyone!
to save $, u can do bilstein 5100 adjustable shocks up front with stock springs for 2.5 lift or fj coils for 3in. & use a spacer with 5100 out back. Bilstein Height adjustable front and matching 5100 Rear shocks - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits http://www.toyota-4runner.org/suspension/78933-4th-gen-all-whove-done-fj-swap.html shocks, install , aligment will be about 600- 800 depending, ome with install & alignment may be close to 1000 & up.
Thanks for the tips... still not sure what I'm going to do yet. It looks like I'll be dropping about $3,K when its all said and done. My current system has the XREAS, but with a little over 100,K miles now, it probably needs an upgrade anyway.
I have the OME on mine which replaced the X-REAS and am very happy with on and off road.
