OME Lift Coils
Are you referring to the 884 model? And at the top it says for V8 and V6 but it says provides 1.5" of lift on a V8. It doesn't mention V6.
It seems 884's are the most popular with the non-aftermarket bumper/winch crowd. V6 and V8 guys use the 884's and occasionally the 885's. There's only 160-200lb (depends on where you read) difference between the V6 and V8.
The 5mm trim packer is something I was suggesting for either engine and only on one side, the passanger side. Most claim the battery, driver and fuel tank all cause a list towards the drivers side.
Keep in mind most of the specifics of T4R/OME that I know is from here and many have done it T120.
Did you see this thread? http://www.toyota-4runner.org/showthread.php?s=&threadid=49701
:cheers:
Yes. So i would do the trim packer fron a rear left side correct? Also while you're answering my questions. Do you know if the 285/50/20 would be okay to use. It has a 31.25" diameter i believe. As opposed to a 275/55/20 which has a 31.8" diamter. The only thing I was concerned about would be the width of the 285? Any input on that? This is all for just leveling out the front btw.
I just ordered my OME setup yesterday from toyteclifts.com. Dieselwolf hooked it up with a coupon code for 5% off. Mine came out to be $769 w/ front diff drop kit and shipping. The coupon code is 11209.
The trim packers are for the front and usually go in the drivers' side front to raise it a bit. The 275/55/20's should work good if your offset is between 15mm and 0. Some use 285's. It usually requires an offset of zero or wheelspacers or aftermarket UCAs. 285's seem to rub the upper control arm when the wheel is cut all the way and the offset is stock (30mm).
The T4R uses a hubcentric rim design. This site helps with wheel terms, sizes etc. http://www.rims-n-tires.com/rt_specs.jsp
Good luck and the price boozng posted looks pretty good.
:cheers:
