djbrand1
Finally got to installing the OME lift kit I got from Toytec. It was a long afternoon putting this on outside in 90 degree heat. Took me about 5 and half hours.:violin: Front left shock took about 2 hours. Got the stock one out quickly, getting the bottom shock bolt back in on the new one was not possible. We had to take the 4 bolts that hold the knuckle to the lower a-arm. The bottom bolt wouldn't clear the cv joint by about 1/4 of an inch. The passenger side took about 15 minutes, the lower shock bolt slipped right in. Did it the same way each side, not sure how we got lucky on the passenger side. A pry bar here is pretty helpful to get the swaybars endlinks off as well. For the rears, the hardest part was getting the shocks out. Wedged a wrench on the top bolt and used some vice grips to twist the shock out. This rendered the old shocks useless, as they were pretty crushed by time they were out. New ones went in easily. For the springs I just left a tire on the opposite side and jacked it up to drop the side I was working on enough that the springs came out and went in easily. Diff drop was pretty straightforward. Luckily, I had access to a lift for this, but I see no reason why you couldn't do it on jackstands. It did give me an opportunity to change the oil and lube the drive shafts. Heres the pics!
Before:
During:
Diff Drop:
After:
Before:
During:
Diff Drop:
After:
