what would be better OME or Toytec Ultimate?? i know most will say toytec cause the adjustability but other then that does one have any significant advantage over the other? thanks
thats what mine is lc coils are cheap i got mine for 60 shippedwhat about Landcruiser coils hybrid lift..
I was talking to a yota geek and he told me to get the lc coils and for the front get the OME Tundra coils and that would level it out around 5-6".
You simply cannot do more than 3" of suspension lift in the front unless you SAS or do a lame drop CV bracket lift. Your CVs won't handle anymore than 3".
Thats not entirely true... if you do a 2" diff drop you can go to 5" inches...
Dude on RM4wd.org here in denver has done that...
I have heard of more than 1" diff drops, but realistically I can't see how they are functional. Because with my 1", my diff is pretty much sitting on the frame crossmember and can't go any lower. It could rotate, but that will just put stress on the driveshaft/u-joints instead of the CVs. I think it's a case of "robbing Peter to pay Paul". I would like to see more info on this though, never seen it in person.
But, he can also swap out an axle in 30 min by himself so if he breaks one, no problem.
Hence his Nickname "Axle"
hahaha. :guitar2: Wow, I'd like to see his rig.
what about Landcruiser coils hybrid lift,
how about sonoran steel?
how about fabtech lift?
what about a Solid Axle Swap, then you can lift it too..
