ome suspension question
Guju4Runner
hey guys so I just order front and rear coils and shocks for the truck.. excited to say the least... had a question though this is the setup
Ome mediums 884 front coil
Ome twintube shock N140s
895 rear coil
N142 rear shock
now.. I was wonder if that's going to give me a level stance?.. I know I read on a site somewhere that you still needed a spacer up front to get a full 3" lift..is that true.. and if it is has anyone tried installing a cornfed 2/1 spacer..will that work to level it out after the new coils and shocks???
thanks in advance guys..
OME gives pretty much even stand, so no spacer needed.
What engine do you have?
884 are good for V6 with a bumper or V8 without it. In this configuration you'll get 3" on front.
895 will give you 2" on the rear. N142 will be firm if you're not running loads in the trunk or tow something.
Thanks alex.. one more question.. lets say i still wanted to go bigger could( big could) i still use the cornfed 2/1 spacer...
NO. Your CV can hold only up to 3-1/2" lift. 3" is where it has to be, otherwise you'll kill your CV very soon. I have to do a major mods and rop bracket to lift mine for 7".
