Only open this if you have an OME lift. Quick question.
trey99ek
So a few months ago I installed an OME lift. 884 coils in front and 2895 in the rear.
Anyone have this setup. If so what size tires are you running without rubbing. It seems 255/70/17 fits great but I looked through about 20 pages of the lift and tire thread and only saw one member with an OME lift.
255/75/17's fit on a stock 4R with no rubbing
If you're lifted, it'll have even more clearance.
If you're looking to be stanced, I'll show myself out the door.
Nope. I'll get getting new tires soon and since I lifted it may as well stuff what I can easily fit in there. I've just heard so many things and various opinions. Just finger did ask those who have the same setup. I dont want to add any spacers either.
i have basically the same set up, i dont have your size tires but i am running 285/75/16 and only rubbing in the front when i turn sometimes (the front part of the fender liner). the rear is all good.
I can't recall which OME I have (heavy - front, medium-rear) with my 285/70/17's but the rub badly when off-road. Nothing to speak of on the pavement though.
I have OME 885's in front and Toytec RCC2.0HD in the rear. I'm running 265/70/17 and no rubbing at all.
I'm hoping for 285's, but will probably end with 275's so I don't have to trim the fender or do a BMC
883s and 255/75/17s
And the only resulting rubbing was on the bit of the mudflap that extends into the wheel well. I Just took the dremel to that part and its fine.
V6, 883's and 895e's paired with Nitrocharger Sport struts & shocks (full OME 'lite' setup). No accessories [weight] other than a bike rack hangin' off-the-back and at the most I'm loaded-up with three guys and gear which is only a moderate load (and I rarely ever tow).
Run 265/65-18 AT-style tires (equivalent of 265/70 17's) and have plenty of room to spare when rolling across typical mountain trails here in CO (rocks, roots, washboards, ruts and approach/departure requiring a reasonable level of articulation, etc.).
I've only had this setup since April but I have had it up in the hills (fishing, biking, casual 4-wheelin'). Admittedly I'm not looking to "beat my ride" and I don't try to max it out so maybe I'm not a good example for input...but nothing remotely close to rubbing with this setup/tire size. Not looking to hammer, cut, grind, or "stuff as much rubber as as I can just because I can either," not necessary for my use.
Poke around with some tire calculators, here's one of many and do some basic measuring before you buy.
Thanks guys. I don't think I'll shoot the 285 route. Really thinking of going 265/70/17 now. Just gotta find a good deal. Sadly I need new UCAs too
OME here with 285/70/17
I have a full OME suspension setup, 883 in the front, 895E in the rear. Last weekend I had 285/70/17 Duratracs installed.
Keep in mind my wheel specs are 17x8 with 0MM offset.
No BMC needed, no rubbing there. Front bumper was slightly trimmed, and fender liners were pushed forward.
I never had front mudflaps, but I would certainly remove those.
