Optimum Opti-Guard, 22 months Later
Whiplash Willy
22 months ago (June 2013) I had my couple month old 4Runner Detailed and Opti-Coated (AKA Opti-Guard or Pro version) at Attention 2 Detail NW
Attention 2 Detail NW. Attention to Detail NW | Opti Coat in Portland & Vancouver
For those not familiar, Opti-Coat\Guard is a “Permanent” coating that will add a 2ml thick coating, that is hydrophobic, resists scratches, chemicals, and contaminants. It is permanent in the sense that it can only be removed with abrasives, such as polishing.
Here is my original thread for more details:
http://www.toyota-4runner.org/5th-gen-t4rs/143594-opti-coated-runner.html
This is a somewhat new product in the detailing industry, and it has a lot of skeptics, as it almost sounds too good to be true.
I started this thread to give an update on how my Opti-Coat has held up over the last 22 months. Since it was applied, I have done no maintenance on the coating. All I have done is regular hand washing, which the frequency started at once a week, but has slowly declined to once a month.
As you can see in the pics below, the coating has maintained its water beading and hydrophobic properties, which haven’t changed since the day it was applied! The finish has remained mostly swirl free, except a couple of areas that I may have scrubbed a little too hard, with a not clean wash mitt, however they can only be seen under certain light. I did get a 1 in long scuff in the pass door, when I let my wife take the 4runner to Costco, and someone had opened their door into mine, however it completely came out in the normal wash.
These pics were taken after a quick wash, after 3 weeks of daily driving:
Water not beading because of surface contamination:
There are some areas where the water no longer beads well. The lower sides of the doors, rear quarter and hatch. These areas are regularly caked with road grime. Opti-Coat does resist contaminants, but it will hold on to some stuff, however the grime can be easily removed with a clay bar. In a few months I will be doing a thorough wash and clay bar to fix this, which will have been my only maintenance outside of washing.
I have had experience with Opti-Coat 2.0 (Consumer grade version) that I applied to my last car. I had it on my car for 12 month, before I sold the car, so I knew what I was getting into with the Opti-Guard. It has held up well, and I have no doubt it will hold up for years to come!
This coating is great for those who want to protect their paint, and keep it looking good with minimal maintenance. I would have to clay/polish/wax every 6 months to maintain this kind of finish!
One of my favorite things about this coating is how easy it is to clean! Washing and drying is much easier, as dirt/tar/grime easily come off, and drying is easy with its water sheeting properties. Also bird poop and bugs easily wipe off. In between washes, bird poop can easily be removed in a single wipe of a wet cloth, or paper towel! Also, harsh cleaning chemicals, like highly concentrated APC, won’t damage the coating.
Etching and light to medium scratches won’t make it past the coating, and can be polished out of the coating, instead of your factory clear coat, which these days is very soft and thin! And if you end up polishing through the coating, you can always easily re-apply it to that panel, unlike clearcoat!
On a sidenote, check out what Paul from A2DNW (Who Opti-Coated my 4Runner) just finished detailing!
Thanks for the long term update; I've always been curious about opticoat. I'll probably be doing it the old way. It gives me something to do.
I'd love to see how this stuff holds up to getting bushwhacked with juniper and pinion pine. One of you should come drive your $40,000 opticoated 4Runner around my desert for a bit. :)
Nice Enzo! And 4runner as well.
Too bad the Opticoat 2.0 got discontinued, replaced by Optimum Gloss Coat. 2.0 was good stuff, but could be a hit or miss with some clear coats. Never have used the Pro version.
LOL I have a few of those to buff out as we speak and I barely brushed up against them... bastards
so in other words it s just like car wax lol:hiding:
I was/am pretty skeptical - but the more I've learned it really seems to be an alternative to regular wax that lasts for a few years. Considering it's about $50-70 for the stuff and maybe 4 hours to prep and apply and let cure, it may be worth it. I pretty easily spend $50-70 on wax over the course of 2-3 years. And I spend a lot more time. I usually do a two or three stage polish every year or two to take out all the scratches an polish the pain. If I could avoid that just once it's worth the time.
Then again I bought a white 4runner this time so I wouldn't see imperfections.
Well....Yea....but its a wax you only apply once, instead of every 6 months, and it does protect your finish better then regular wax. Also, If you wanted to go the Wax Route, and apply it every 6 months instead, you would need to clay and polish before applying wax each time. Claying, Polishing, then waxing the 4runner is a pretty big job! I rather have better results, with less maintenance.
WW - you never said what this treatment costs.
philsey, that isn't an easy answer. The application of the Opti-Guard (Pro) product, which can only be applied by authorized dealers is in the ball park of $600. Where the real cost comes in, is the paint correction, as you wouldn't want to put a permanent coating on contaminated, and scratched up paint. I think Optimum actually sets the price authorized dealers have to charge for the application now.
Even though my 4Runner was only 2 months old when I had this applied, Paul still need to Clay, and Polish my paint, as it had water spots, and some scratches. I think the surface prep (Cleaning and ect) was included in the application cost. So really the only way to know is to take it into an authorized dealer and get an estimate. You may be able to save some money by doing some of the prep work yourself, but that will depend on the installer.
I never was specific on what I paid Paul From Attention 2 Detail NW, because he gave me a really good deal, and even did some extra stuff for free, since we got along well. He asked me not to reveal my cost to others because he can't give that deal to everyone.
When I applied Opti-Coat 2.0 (The discontinued consumer version) to my 2012 Golf, the coating cost me $60 (and I only used half) and i probley spent about another $40 in prep stuff and applicators. I did all of the prep myself, and then hand applied it.
Yea, it is sad about Opticoat 2.0, that truly was too good to be true. It was pretty much the same as Opti-Guard, but it took longer to cure, so you could fix mistakes easier. I haven't read up too much on the Optimum Gloss Coat, but from my understanding it only lasts a couple of years, so it is a gimped version of the Permanent Opti-Coat 2.0
I was skeptical as well, but after I applied it to my Golf, I swore I would never own another vehicle that isn't Opti-Coated/Guarded. It makes it so much easier to wash, and it is very low maintenance. I don't know that you can find Opti-Coat 2.0 anymore, so you may have to settle with Optimum Gloss Coat.
If you are already going through the work of polishing and waxing every 1-2 years, it doesn't take much more work to subsitute the waxing, with applying the coating. Opti-Coat 2.0 was just as easy to apply as wax, just a little different.
hehe, or be like me and don't care :)
haven't washed mine since last year. Subaru before, I went about 2 years between washes.
its just going to get dirty again anyway. and if you leave it outside for hour, the wind will cake the dirt on it after a car wash anyway.
That's is such a shame Opti-Coat 2.0 is discontinued. Prepping the paint (correction) is what kept me from buying it. Oh, and the time required as well. With baby #2 coming, there is NO way I can accommodate HOURS of prepping the paint. Paying a professional wasn't going to happen either. Maybe with a new ride, yes.
I expect to get a Porter-Cable buffer this year and go nuts with Meguiar's 105 and 205 products. If it's still available, I grab a bottle of Opti-Lens for my lights.
Your rig still looks incredible!!
