Ordering Custom Springs
alawson
So I've decided to order custom springs from Alcan, and as much as I've read about leafs, shackles, hangers, etc. I still don't feel confident I know enough to explain everything to get a spring custom made for me.
I have a stock 1985 4Runner, and the leaf springs are sagging like hell. It will be mostly an overland truck, but I'd like it to be well rounded.
Spring: 3" lift, Alcan
Shackles: 4Crawler, greaseable
Front Spring Hanger: Low Range Off Road
Shock: Bilstein
Tires: 33x12.5... maybe 10.5
Is there a certain length I should be asking for them to make the leaf springs? Bill asked me how long I want them, and honestly I have no idea, I just figured they'd make them however long they needed to be.
I'm assuming I'll need new shackles, which I was planning on getting from 4Crawler. But what size?
I'd like to keep my 4R as low as possible, but I want to fit 33x12.5 tires without trimming anything.
Any help or insight would be much appreciated. :cheers:
Easy solution: buy Old Man Emu.
Correct solution: know your travel weight. Read, learn, calculate spring and dampers accordingly.
Stock locations? Measure. Google what defines a leaf spring. Length? Arch? Overload?
I will go read up on it again as well.
And don't fit fat tires please :) Useless unless in sand and to me it looks weird. But if you like it, it fits the truck no doubt.
Thanks for the response. I considered OME, but I’d really like to get 3 inches, and don’t want to go the HD route for obvious reasons - not meant for 3 inches.
I’d like to spend money on a quality long term setup. Something I can upgrade/fix and forget about it for a while. Not going to be a crawler so I hope to break less stuff by choosing quality parts off the bat.
I understand the sentiments about the wide tires haha. I’ve read that several times on the forum. I’m not 100% sold on it, I’d just like the flexibility of a setup that could handle that wide of a tire regardless if I actually get those at this time.
AndiGarage
