Original tires or TRD tires/rims.
HNTMUP
Hoping to finally upgrade to a 17 next year. Is it more cost effective to order with the TRD tires and rims or buy 17" tires and rims and upgrade on my own?
Thanks,
JDG
What are you running now, a 16?
Only change the rim if you are actually trying to accomplish something... like trying to get more offset/backspacing or trying to clear the larger brake caliper with a 17. Its worth looking into that now so you dont have to do it twice.
I personally use the smallest rim possible so I can maintain more tasty sidewall.
That said, I would probably buy rims and tires separately ... Not really sure what the TRD tire is, but chances are you can probably make a better choice for whatever application you need it for...
For example a KO2 or nice BFG MT might be in order and probably better than whatever Toyota putts on as an OEM.
You can probably expect to pay about $15-20 per tire for mount and balance at a tire shop if you bough separates.
I guess the initial question is what size tires are standard on the Trail Premium/Off Road Premium models?
