OTRATTW switches.
Big Daddy K
I recently installed the Rigid industries SRM back-up light kit in m T4R. The switch it comes with is functional but less than appealing. I like that it can be on /off/auto and would like to retain that functionality. AOB does not have any DPDT switches for Toyota direct replacement. But they do have this-
12 volt 20amp ON-OFF-ON LASER Etched Rocker Switch white -Air On Board
This switch- High quality Carling Technologies custom laser-etched rocker switches, using Carling Technologies L-Series line of rockers and switches is about the closest thing I could find to a drop in solution but I can't find mention on anyone using the L series in a 5th gen.
So I am looking for suggestions of switches that will work. I considered using a switch pros but they said it won't work with an auto function.
Pics would be great if you have a DPDT 3 position switch in your dash somewhere.
Thanks all.
Does anyone have any other suggestions for a DPDT 3 position switch that will fit in the factory cut-outs? Both of these give slightly different dimensions and both say they fit the industry standard knock out holes. :shrug:
I am in the process of installing some Rigid back up lights as well and am wondering if you found a ON-OFF-ON switch for this purpose?
Thanks...
I’d check the FJ forums. We use the same switches and I know I have seen OTRATTW switches used on some rigs there when I owned my FJ.
Philthyphilthy
