Not a troll...
Not a troll, but maybe it's still okay to comment?
It looks like you were getting pretty good advice. When I watched, your spotters seemed to say what I was thinking
What was that coming out of the front of your 4Runner at about 17:10? Was that a 'Spiderman web?' Can't be a tow rope, that would just be wrong! Lol!
I heard a hard thump near the rear at one point. Be sure to check your exhaust. I had a similar experience in a dry but very rocky area that I tried to keep all the tires up on rocks not to bottom out. I ended up hitting the exhaust and it must've cracked at the very sharp elbow above the rear axle.
It failed while towing and WOT and MELTED a bunch of stufff
Not a big deal, easy to replace the exhaust section, but if you catch it before it melts your rear speed sensors and hoses to the Emissions charcoal canister, you'll avoid some of my headaches. Lol.
I especially like the crossing at about 6:30ish. Simple, but good advice. Keep the diagonal pivot going, the 4Runner takes it quite well- as long as you don't get one wheel free spinning.
I do suggest low range, diff locked, turn OFF the RCSA (rear side curtain airbags). LOTS of mean power and crawling available.
The thing about the water is to be sure you have the sealed differentials and transmission, or extend the breathers in a watertight manner yourself.
Not sure, but from the hood, looks like you have the SR5? My Limited comes with the sealed tranny and breather extended on the diffs (Sadly, I just read it may only be the front and I have to make one for the rear?) Not sure about the SR5?
I also like how you went S-L-O-W-L-Y into the obstacles. That is often the difference between maneuvering and smashing to sh$%^^. Patient and technical often results in different results than the 'much lighter wallet' version of 'blast and survive' that the inexperienced like to do.
Thanks for sharing the video! I think most of the views are in the eve and weekends here, so don't judge the quality of your post by the number of replies.
Where was this taken?
