outlet questions
Supra725
so I after going thoroughly after the wheeling trip..
I notice my back outlet and 1 of the 12v outlets are out..
is there any where I should start to look?
also, is it possible to bend one of the running boards bracket back?
thanks.
Did you check the fuse?
As far as the running boards, my brackets are bent to poop, but they are metal so yes you can. I have always used a prybar, hammer, and vice grips to bend stuff pack on my 4Runner.
Just check the fuse and replaced it with the new one. No dice.
I might go get another newer fuse to try it out.
The brackets still needs a little bit of bending.
