Overland Rear Suspension Problem
hidyho123
So this past weekend a couple guys in Blacksburg went on a wheeling trip and everything seemed to very smoothy with the new suspension and tires... however, today I noticed a slight lean in my rear suspension on my 4Runner . It is about 1/2-3/4 inch difference between the driver side and passenger side (driver side is the one that is leaning). I thought it might just be because of the gas tank, but I feel like in the past ~2 months I would've realized it beforehand. I am planning on calling Overland and seeing what they say, but I wanted to check on here first and see if anyone else has had a problem like this and what they did about it. Thanks!
hidyho123
I'm not sure how accurate that is, but I know for a fact before I went on the trip they were both 39.5 inches and now the driver side in right at 39 inches.
Alright well thanks for the threads/help! If I wanted to fix this (because it does kinda annoy me), would using a spacer just on the driver side work/be the most cost effective? and would it cause any problems?
Many people crank up the front driver side coilover to help offset this lean, Or keep all their heavy cargo on the passenger side.
Short answer, Yes. I actually just did the same thing on mine. After my install, my driver side rear was almost a full inch lower. After I installed the DS 1.5" rear coil spacer, all sides are within 1/4". Due to the rear coils placement, both rears were lifted as well as the drivers front which helped to even it all out.
I am really considering putting a spacer in, but it still boggles me how in ~24 hours my rear goes from level to a ~1/2 inch lean. Does DS or any other brand make a smaller spacer like a 1/2" or 1" spacer? Since mine isn't off that much I don't think I would need 1.5"
If you do, let me know what you find out. I'll be swapping to coils here shortly (have OEM air bags) and will probably use that if it will work.
