OW extended shocks with OME 896 coils?
aha2988
Does anyone know, can attest, think it will be ok for the meantime to run the OW 2.5 extended travel rear shocks with rear OME 896 coils I'm purchasing the kit from OW from there close out sale which doesnt come with there coils there recommending the use of a coil with a 15.75" or taller free height, about 3/8" taller that what OME seems to spec there 896's at 390mm of height. If i run the extended travel kit with the OME coils will i run into coils poping out if so can i just fab a 3/8-1/2" spacer plate to get the free height needed. I know the springs will be way firm compared to OW's coils that would normally come with the kit OW's spring rating: 200lbs-280lbs pending weight and the OME 896's are at 318lb of spring rate. I dont mind sourcing new coils I just mainly want to know can i wait and replace the coils later or is it going to be a must to replace the coils before the extended travel kit is installed any feedback is greatly appriciated thanks guys
7ron
