i have the code p0302 cylinder 2 misfire code coming up. i've changed the spark plugs and spark plug wires with all oem toyota parts. still getting misfire in cylinder 2. is there anything i could do to try to fix this or am i gonna have to take it in to get looked at. should i get new coil packs. can you switch the coil packs to see if the code will change if that is the problem. any help would be great. thanks, i also have a code reader to check so no needing to go to autozone all the time. thanks
