P0430 - which sensor to replace?
tx4runnerag
I'm getting a P0430 on our '04 4Runner (1GR-FE). From what I've read, it sounds like IF this is a bad sensor and not a bad catalytic converter, it's the one AFTER the cat - is that correct?
Is there an easy/quick way to test the O2 sensor to determine if that's the problem?
Also, from what I've read I believe bank 2 is the driver's (left, if sitting in the vehicle) side - is that correct?
P0430 is a bank2 catalyst efficiency code. When a downstream/post cat O2 sensor signal is alternating from rich to lean fast, the cat is less efficient.
i got this code the other day. I believe it's the right side, and of course, I had an aftermarket header put on because Toyota can't sell anything for the 4runner for under a grand (major parts). Reset it with my obd scanner.
history on mine...both o2's on that side are within 1.5 yrs of age, new and toyota brand.
Quite frankly I am sick of my 4runner.
Suspension starts leaking, dealer says it's going to be $1500 a side to replace the xreas. I buy toyota springs and bilstein shocks.
Frozen calipers all day long
ticking due to cracked manifold...$1700 to replace each side at dealer
wheel bearings are making noise now
those are the major things, i have more to share LOL
Terrible on fuel to boot
Selling this thing after the winter. Done and done.
