Painting Fender Flares.. What paint?
ceebs40
Well, i've decided it's time to paint the faded fender flares. After thorough research through the forums, i'm unable to find an answer to my question:
1. What paint do you guys/gals recommend? I've heard a few things about Rust-O-Lieum, but it seems that the better product is SEM (according to a auto paint supply shop).
2. Is the color just a flat black? Only reason I ask is because the fenders look to have a grayish tent to them (probably due to age, sun, etc.).
Below are a couple photos, one with them on, and one with them off. I plan to sand with 300 or so grit, then a wet sand with the same grit, dawn soap to remove any grease, and let dry.
Any words of wisdom would be greatly appreciated! :guitar3:
I used a bumper coating as the main paint instead of traditional paint since it should hold up better and I didn't want a real glossy look to them. I cleaned them with the prep spray and then used a solid coat of adhesion promotor and then laid down 5 coats of the bumper coating. Came out looking close to OEM but if it fails to hold I will give straight paint a try but so far they look good after a few months and a couple of snowstorms. I do still need to try it on the lower valence but that'll have to wait til spring.
P1010235.jpg~original
P1010234.jpg~original
P1010509.jpg~original
@RonMAIDEN - That looks real nice. So Dupli-Color is what you went with.
It does look very close to OEM. I spoke with a SEM rep, and he said the black was more of a satin as opposed to a flat, but not a gloss. I'm a little worried it may be too glossy..
Overall very nice job. Thanks for the response.
I have one vote for Dupli-Color, anyone else?
I used SEM on my trim/bumper but they did not sell duplicolor where I bought my paint. They are prob equal is terms of quality.
is it true that OEM SR5 flares cost about $100 - $150? if so then just buy new ones.
TRUST ME, that rattle can paint will fade in 1-2 years or sooner! depending on where you live.
No more than 1-2 years? I'd like to get more like 5-6. I haven't checked but i'd think all new are more around $300-450 directly from Toyota. I'll call tomorrow. :hunter:
well I am no expert but yes, I think if you paint it flat black without protective overcoat, getting 2 yrs without noticable fade would be quite good.
Also, I think it is the limited flares that are $500, not the SR5 but i cannot say for sure.
IF you can find the smaller plastic SR5 flares from a dealer they will cost you easily north of $300 and they aren't readily in stock in most cases and even the used market isn't going to be cheap and another case if you can find them.
What about Krylon Fusion paint? I know several J**p guys that have gone that route, and say they've had good success. But I have no first-hand experience.
I just installed my flares a few weeks ago. I was planning on going body color initially . But I think they are going to scuff easily. I plan on painting them and my lower front facia with spray bed liner. I already did my rocker panels after I removed my running boards . And it looks great..
