Painting the interior plastic parts?
bak3rme
Senior Member
I was wondering, is it possible to paint/spray the plastic interior parts? parts such as the center piece where there are 2 cupholders and the odd bucket? also the plastic piece around the steering wheel? and around the key ring? (its all scratched up back there from keys). mostly its just all the black parts on the truck that i would do.
is there a special paint? because i know regular spray paint probaly would not work. i would guess it would heat up in the summer and crack and peel.
yeah gotta agree with you there having a black interior is no where near worth the effort imo.............
but you have to admit it does look nice, and it's kinda cool to have something different, i suppose if i didn't have a job,a girl, responsibility , life, or anything to do in general, i might give it a shot but i'd rather be at the lake if that was the case.. lol
wow i looked over that post, it looks really nice, but i dont think i could find time to do all that, however my interior grey is starting to look kinda blueish/purplish in a way. just gunna do the black parts for now and maybe black doorhandles. do i have to sand anything down?
he said
I pretty much hit the plastic parts with automotive primer first. This next phase I'll be using automotive plastic primer which might be better than the original. Anyway, once I primered everything, I put on several coats of the duplicolor fabric / vinyl dye / paint. The vinyl parts I just cleaned with prepsol and alcohol really well. made sure everything was dry and nice before painting and I did sand a little between coats."
but said nothing about sanding before priming or painting
this part
These pictures didn't turn out so great but today I primered and painted the main dashboard and the console. I need to wet sand and add another coat of paint before reinstalling it into the car. I'll take better pictures tomorow.
beyond that i cant comment you might want to try a few test pieces first and read the directions
You do not need to sand or primer anything before spraying it. You should wash the parts in warm soapy water and use a nylon brush to clean out the textured surfaces. Let it dry and wipe it down with alcohol. Just make sure you set the pieces to be painted on a clean surface and don't touch any cleaned piece with your bare hands.
