A few weeks ago my 4runner would not start... Tested the battery and the dealership said it was bad and replaced it under warranty...
A few days ago the symptoms returned and I was fearful it might be the alternator.. I had it tested and everything came up good..
I started checking for parasitic leaks and could not find anything obvious causing it.
This is when it gets fun..... After pulling a million fuses it felt like I unhooked the hot lead going to the main bus panel up front and the drain stopped.... Must be in that panel right? So then I unhook the starter, alternator, and AC motor.. the drain is still there... Mind you after pulling all the fuses one at a time in the panel I still could not get the amperage draw to drop below 2.5amps.. So... I revert back to my profession.. I stop by the fire station and leave the truck sit outside in 20degree weather for about 2 hours and come up with the thermal imaging camera... sure enough.. the only relay showing hot was the dome light relay... pulled it... no drain.. no dead battery this morning... All the dome lights are off.. all the doors were shut.. Im assuming either a bad relay or faulty door switch.. Any ideas?
