In the process of replacing pads/rotors on the left rear brake assembly of my 2005 V8 4WD 4Runner I bent one of the shoe hold down spring pins. I'm new to drum brakes and didn't release the parking brake tension properly. :noidea:
Replaced the pin, and everything seemed to go back together properly in the drum system. The only thing that I forgot to do was properly re-adjust the parking brake. I had the adjuster tightened almost all the way in when I installed everything back together and that's how I left it.
Now, I've notice a cyclic noise that increases in cadence with wheel speed. It seems to appear whenever I make a right turn and for a short while when I first drive the car after it's been sitting. To me it seems like the brake shoe towards the rear of the car has to be hitting the rotor to make the noise.
Could a loose parking brake adjustment cause that or could something else have not gone back together properly in the parking brake assembly?
Thanks in advance,
Aaron
Thanks in advance,
Aaron
