Part ID needed, making clicking noise
Arn24
This part just started clicking, loud enough that I can hear it in the cab. I'm pretty sure it's coming from this part as I could feel it clicking when I touched it. It seems to do it more the colder it is. Any ideas what it is or why it would be making noise? Thanks.
Negative on the codes, and everything's running fine. Gas mileage doesn't appear to be affected, although it's hard to tell as it always takes a hit when the winter gas hits and using 4WD in the snowy stuff.
VCV? Vacuum Control Valve?
I think you mean VSV, or vacuum switching valve. Googled VCV and came up with that. Pics seem to verify that it's probably what I'm looking at.
VSV (I was close). Just had to replace one a month ago from a p0446 code. That looked like the charcoal canister at the bottom right of your pic, but I was working on an '01 (2 VSV's under the hood, Canister and VSV #3 in the rear). If you're not getting an evap code yet, then it's obviously working. Maybe it's getting ready to poop out. They're supposed to make a click noise when voltage is applied. IIRC I got one from Advance Auto (Dorman) for about $40.
Philthyphilthy
