I was wanting to convert my 1995 to the manual locking hubs. Will the hubs off your Gen1 work on my 1995?
If so, how much to ship both front hubs with internals to 97219?
That I am not sure of myself. You might want to post this in the general forum and ask the pros on this site. There are plenty of them that could probably lend some knowledge. If so gladly will ship!
Are these the clips you need? Looks like they are all in good shape. I can't get to the tailgate harness right now but I'm pretty sure it's good. I don't know what it looks like off hand. Are you going to just splice it to yours or are you wanting the plug from the door? $10?
You can use those hubs in your 4runner. The only thing you need to do is get rid of your driver side axle tube and use a non add axle tube. Your add axle tube still uses vacuum lines and has a big box with a fork in it to lock and un lock the hubs.
Hi Nugsfan,more pics
Hi Nugsfan,
Are the following still available?
May I have price with shipping to 92127? U.S.P.S. is safest becoz mailman will put items in secure box that only I have the key to. Fedex and UPS simply leave items at front door.
- Main shift knob
- Dome light
- Deck light
- Tail light assembly gasket - if not cracked/brittle
Regards,
RAD
how about the rubber gasket around the tailgate??
I'll have to check tonight to see what condition its in.
I have a problem! Anybody know how to lower the tailgate window when there is no battery? The motor and everything is all stripped out of the car. I wasn't planning on stripping this car when I first took the motor out. Any ideas?
Any reason you can't run jumper leads from a battery to the motor or the pins on the harness?
I was thinking about that but didn't know if it would blow up the motor on the tailgate. So you think I can just take 2 wires from the battery and manually just touch the motor leads and it should work?
I'm pretty sure 12 volts is 12 volts.
Haha. I can't argue with you there. I just didn't want to do something stupid and fry it. Didn't know if the power was stepped down from the battery to the motor. Thanks I'll try tonight!
Sorry don't have the chrome trim. It was trashed so it was replaced with a rubber one when I put new windshield in.
:gun4:
What type of rubber trim did you use?
:gun4:
Yes main shift nob available-$5
Dome Light and Deck light I've had somebody inquire but have not heard back yet. If I don't hear back today it's yours-$5 each
Tail light assembly gasket-I'll have to check. Are you looking for both?
