Parting Out: 1991 SR5 4R - 3VZE - Auto
99blackSE
Hey guys/girls, I'm kind of new to the board but below is some trade feedback from a local site:
feedback.jpg~original
I am located in Manitoba Canada, close to Winnipeg.
I picked up this 4R back in late April for the tailgate as my old one was pretty banged up. Since the truck is quite unlike mine (auto/power everything) there are quite a few things I can't use.
The truck suffered a rollover that crunched the roof from the sunroof on but not enough that I couldn't sit in the thing to steer when taking it off the trailer.
VIN: JT4VN36H6M0010558
The mileage is 296,xxx km, so about 175,000 miles. As far as I know everything electric was in working order prior to picking up this truck. The motor is a little stiff turning over, suspect oil on top of the pistons.
I have stripped almost the whole truck on the inside, including pulling out most of the wiring.
I will be going up to Churchill Manitoba for fieldwork from August 19-28 so I will probably not respond during those times.
Parts gone already are:
- Front Bumper and metal piece below it
- Front seats
- Mud flaps
- Tailgate
- Rims
For suspension/engine/frame components it may be a month before I can get to that part of the truck.
Thanks for looking.
wreck1.jpg~original
Some shots of some parts. They will be cleaned up prior to shipping. Throw me some offers.
IMG_7542s.jpg~original
I had this sold locally but the guy didn't have this connector that is in my hand for his. I think it is for the lights because everything else worked for him but since he didn't have that connector...
IMG_7544c.jpg~original
Speed control actuator.
IMG_7545c.jpg~original
IMG_7547c.jpg~original
Deceleration sensor.
IMG_7549c.jpg~original
Power Antenna motor. I just cut it out of the fender to avoid hassle/breaking it as I wasn't quite sure how to maneuver it outta there.
IMG_7589c.jpg~original
IMG_7590c.jpg~original
Rotor:
IMG_7591c.jpg~original
IMG_7592c.jpg~original
Coil/Ignitor:
IMG_7593c.jpg~original
IMG_7594c.jpg~original
IMG_7595c.jpg~original
These two are part of the EGR system I think, not sure what they're called exactly:
IMG_7596c.jpg~original
IMG_7598c.jpg~original
Dome Light:
IMG_7597c.jpg~original
ECU:
IMG_7599c.jpg~original
IMG_7601c.jpg~original
Sunroof Controls:
IMG_7602c.jpg~original
IMG_7603c.jpg~original
IMG_7604c.jpg~original
Have no idea what this is, had a bunch of vac lines running to it:
IMG_7605x.jpg~original
IMG_7606c.jpg~original
Engine Harness:
IMG_7607c.jpg~original
Interior Harness. Unfortunately with Manitoba's communist public insurance corporation mandatory immobilzers are in effect for quite a few vehicles so some of the wiring was spliced here.
IMG_7610c.jpg~original
I took a shot of it here:
IMG_7611c.jpg~original
Hood Release. I have the cable too, just didn't take a picture.
IMG_7612c.jpg~original
Fan:
IMG_7613c.jpg~original
AC Condenser
IMG_7614c.jpg~original
Rad and hoses:
IMG_7615c.jpg~original
Horn:
IMG_7616c.jpg~original
Coolant Overflow/Reservoir:
IMG_7617c.jpg~original
Windshield Fluid Reservoir:
IMG_7618c.jpg~original
Wires (Yakazi):
IMG_7620c.jpg~original
IMG_7621c.jpg~original
The heater core/ac core/blower fan trio:
IMG_7622c.jpg~original
Fuel injector rails:
IMG_7623c.jpg~original
This part feeds a coolant passage to my best guess, goes through the timing belt cover:
IMG_7624c.jpg~original
Intake Manifold:
IMG_7625c.jpg~original
HVAC Controls:
IMG_7626c.jpg~original
Fan and Shroud:
IMG_7627c.jpg~original
Timing Belt Cover:
IMG_7555c.jpg~original
Centre Console (I have the heater core too if you want them together)
IMG_7559c.jpg~original
IMG_7560c.jpg~original
Hazards Switch:
IMG_7567c.jpg~original
IMG_7568c.jpg~original
AC Switch:
IMG_7570c.jpg~original
IMG_7571c.jpg~original
Speed Control module:
IMG_7628c.jpg~original
Map Light/Mirror Combo:
IMG_7629c.jpg~original
Sunroof Motor:
IMG_7631c.jpg~original
AFM:
IMG_7632c.jpg~original
Glove Box:
IMG_7633c.jpg~original
Rear Wiper Motor/Bracket:
IMG_7634c.jpg~original
Alternator has been tested and works fine. It was remanned by Denso.
Does this 4rummer have crank windows? I am looking for a driver side arm rest for a door panel with crank windows, no power locks.
Still have some parts left, oil cap, gas cap, trans and oil sticks. I just got another truck in but will probably make a separate thread for that or not if the snow flys here soon.
Do you still have the transfer case shift linkage?
If so how much shipped to Texas 78414 area code? Thanks
<a href="http://s270.photobucket.com/albums/jj91/Philipontesenuts/?action=view&current=Shifterlinkage.png" target="_blank"><img src="http://i270.photobucket.com/albums/jj91/Philipontesenuts/Shifterlinkage.png" border="0" alt="SL"></a>
Do you still have the sunroof switch? Also, I'm looking for the passenger side running board rear endcap. That's if both of those parts will fit on a '95
Sorry 4running but that's in pieces. I don't think I could put it back together as it's missing some bolts.
Yeah still have all the running board stuff. I'll see if I can get my dad to pull the plastic parts off quick before the truck is sent away. Unfortunately the sunroof controls just left me a couple days ago, sorry I forgot to remove that picture.
Cool. How much sent to zip 92840?
Mostly depends on the size of the box, I'd say it'd be around 15-20 bucks expedited with a tracking number. I can get you a more exact quote on Friday. My dad pulled them off today so they're sittin' at home.
its ok i just need the majority of it do you have any pics of what parts you do have of it? Thanks!!!
No pictures of that stuff specifically. If it's still in the yard when I get home in a couple days I'll check it out.
noticed the hood bug flap - also does it have leather seats ... thanks.
No leather seats in this one. The bug deflector is cracked at the corner, missing a 1/4th of it but I do have another one on a different truck.
IMG_8301c.jpg~original
