Passenger Rear .5" higher than Driver's?
oakes
I installed an Ultimate Toytec 3" suspension and the passenger side rear sits .5" higher than the driver's side rears. Any idea's why?
most will tell you it's because of the battery, fuel tank and driver. the added weight on drivers side will lower it a very small amount. Pass. side will be a bit taller. nothing anyone will notice but you.
not a biggie but hope it helps explain it with my lack of knowhow.
If you just put it on that might be why. Let it settle it should level out a little bit. I'm not sure how this this lift works but if it's new coil springs check to make sure they are seated right.
Do you have an empty tank of gas? Mine sits lopsided when Im low on gas. They made it taller because when you have a full tank of gas it weighs that side down.
Go fill up and it will look level.
