Pathrinder (95) rims, will it fit 4R (93)
indika
Hi
anyone know if rims from a pathfinder (235, 75 R15) will fit in 93 4Runner. the bolt patten is the same. will there be enough room for calipers etc?
Not sure about the caliper clearance, but you may have to consider the center bore as well, not just bolt pattern.
..will there be enough room for calipers etc?
After you determine the center bore is large enough, you'd have to compare offset and backspacing to get an idea if they'd fit properly.
Or just bolt one on and see what happens.
