40 series install
So instead of paying 400 bucks for a borla or 700 for a magnaflow catback system, I decided to pick up a flowmaster 40 series from amazon with a turn down tip. I ended up getting 2.5 inch outside diameter pipe and a 2.25 to 2.5 diameter conversion pipe, as the original pipe is 2.25 inch outside diameter.
To remove the old rusted exhaust, I snapped the bolts connecting the y pipe to the muffler pipe, took off the hangers and used a sawzaw to cut the pipe that bends around the axle off from the muffler for easier removal. Drilled out the old bolts and later used a new pair of bolt/washers/nuts.
To keep the existing flange and hanger, I cut off the old muffler from the pipe. Using a 2.25 to 2.5 adapter, I connected the the original pipe to the 2.5 pipe then to the flowmaster. To connect the turn down tip, I cut about 6 inches of 2.5 pipe so it would slip into the flowmaster and the tip.
All connecting pieces were welded using my cousin's Lincoln mig welder. It was my first time welding, so it's not the best. However, no leaks and some black spray paint cleaned it up real good haha.
New issue was finding a way to make the exhaust sturdy as the only usable hanger was right by the flange. The exhaust didn't have a lot of play, but just to make sure, I wrapped exhaust wire, or whatever it's called, around the flowmaster and to the frame. No play and no banging against anything so it held up great so far.
Here's what I bought off of amazon and what it all looks like. It wont let me upload the video of it, so here's some crappy screenshots for now.
Total price was roughly 100 bucks. I guess the price on the exhaust tip changed because I know I spent around 10-15
