FS: 4th Gen 2005 4Runner V8 Limited Nautical Blue, 202k, $12k Philadelphia PA
BLUF:
Clean Title, located in Philadelphia, PA
202k miles
Suspension almost 100% replaced 30k miles ago
Doug Thorley Headers / Cats / Exhaust
Timing Belt good for another 50k miles
New ATF from exchange
New Alternator
Audio System Completely Upgraded
Half the truck frame was SafetyCap’d (much more rust prevention)
Needs tires, has rust but its been maintained
THE GOOD
• Clean Title, PA Inspection exp 3/25
• Falken Wildpeak AT3 265/70-17 including spare (plenty of meat, but End of life)
• Doug Thorley Stainless Headers
• Magnaflow Cats & Gibson Exhaust
• Full XREAS Suspension Replacement / Upgrade
• Bilstein 5100s Front/Rear​
• Moog Springs Front/Rear​
• Cornfed Spacers, Front​
• JBA UCAs, OEM LCAs, Front​
• End Links, Front/Rear​
• Spidertrax 1.25” Spacers, Front/Rear​
• Gen5 Brake Upgrade (Larger Front Pistons & Rotors)
• Stainless brake lines (all 6)​
• Just replaced front rotors this week, pads all have tons of meat​
• OEM Replaced Driveshaft
• Timing Belt replaced @165k (good until 255k)
• ATF Exchanges (13Qt Coolant Line Method just performed this Spring)
• Newly Replaced Denso OEM Alternator
• Sound Deadening 3-layer system installed 100% coverage
• Audio System Upgrade
• Alpine iLX-W650​
• Rockford Fosgate R2-750X5 Amplifier​
• Rockford Fosgate P3SD2-8 8" Dual 2-Ohm Shallow Mount Subwoofer​
• Infinity Reference REF-6530cx/ REF-6532cx Speakers (6 speaker system)​
• Crux CS-TJ20 Steering Wheel Controls Wiring Interface​
• Boyo VTK601HD Rear Camera​
• Fresh audio cable runs​
• Dedicated/Fused Power Distribution​
• Form, Fit, Function Installation (No sub-box, etc)​
• Electrical Upgrades / Goodies
• Northstar Group 31M Deep Cycle Marine Battery (Larger than OEM)​
• BlueSea FuseBox on PowerTrays tray: 300amp service total: 125A amplifier; 125A spare (TBD inverter project)​
• Chassis/Starter Ground Cable 1/0AWG upgrades​
• 12v Receptacles added​
• Rear brake/reverse lights upgraded to LED versions
• Weathertech’s all around incl. rear
• Horn System is 1980’s Chevy 4-Note Horn. Loud but Classy
• Frame SafetyCaps Installed Passenger Side (Frame Rust fixed)
• Frame in Good Shape, Painted & Maintained
Meticulous Maintenance Notes & History Available – I tracked every single thing I did on the vehicle and was able to pull the previous owners Dealership records.
Sale include Various Equipment from TBD Projects, Toyota Coolant, ATF and some misc spare parts included.
THE BAD
• 4WD System INOP – Will not kick into 4LO without tricking the ECU with pushbuttons
• System actually works fine except the limit switches in the Transfer Case (HL1 broken)​
• You can fully operate the 4WD system – if you understand the pushbutton logic​
• Frame Rust – I’ve spent years working restoration and having pieces welded on and fixed. For what it was, its in great shape. But it shows signs of its age in the East Coast Winters. I wouldn’t tow 5500lbs with it but a trailer or basket with a cooler on the hitch, no problem. While above I call it in good shape, every one will have their own evaluation so please take time to review pictures.
• Tires – Tires have been absolute champions but they need replaced as they are starting to dry-rot
• Dash Crack - has the typical dash crack but it's worse than most - see pics
• Wheels –Show their age, they aren’t perfect but they aren’t pretty. For 20 year old wheels they are in good shape.
• P2445 CEL in Winter Temps below Freezing – The Secondary Air Injection Bypass is installed, never figured this out but the code clears with no issues
• No idea what CarFax reports, but I claimed 2 accidents, Side Swipe Passenger Side (replaced the door and blended paint) & a rear end at slow speeds, only some bumper scratches. Nothing major, was accident free before I purchased.
I consider this above average pricing wise as it has new suspension, headers, rust mitigation among many other non-cosmetic upgrades
Asking $12k
Photos Here
2005 4Runner V8 LTD 202k Phila PA - Google Photos
Found my Sound Deadening / Audio upgrade pictures
4Runner Sound Deadening - Google Photos
DM me for more pictures, specifics or the VIN if you want to look it up. Thanks.​
Elchele89
