Pics from Morimoto HID install
4Rager
Let me start by saying this install is actually on my friend's Taco, but it's the same H11 kit as our 5th gens use, so I thought you guys might still be interested in the output and color.
This is the 4500k Morimoto elite kit from The Retrofit Source. My friend has done a lot for me over the past year, so I got him the kit as a new truck/Christmas gift. On my 5th gen I have the Xenon Depot 5000k kit, but after how impressed I was with the TRS LED fog kit, I decided to give their Morimoto kit a try this time around.
Overall the two kits are very similar. The fit and finish of the Morimoto kit is a bit superior, however my one complaint was that the kit did not come with doubled sided tape. Instead of comes with these universal brackets, which I have no idea where you'd go about mouthing them. Every HID kit I've installed has used the foam double sided tape, and I've never had one come unstuck, so we picked some up from Home Depot.
One thing I will say is the Morimoto kit is making me second guess my bulbs. I don't have a pic to compare, but for his being 4500k and mine being 5000k, the blue hue is very noticeable while his 4500k is pure white. The strange thing is, my TRS LED fogs are 5500K and they are noticeably whiter than my supposedly 5000k HID low beams. It definitely looks closer to the blueish output of 6000k. The next time our trucks are together I'll try to update this with some comparison pics.
Way more output:
Comparison vs. Stock. I didn't know this until he bought it, but the Taco TRDP comes with Rigid LED fogs that are super bright.
Cool and what a nice gift for your friend.
Can you provide a little detail about the fit and finish differences you noticed in the two retrofit kits?
Also, I do not know how much this topic is discussed on this forum but there can be a broad color variation between manufacturers advertising products with the same Kelvin value. A Philips 5000K HID lamp will not look exactly the same in color as the same format/wattage lamp from Sylvania, for instance. Compared side by side, the "white" light of one lamp may look more blue, green, red, than the other yet still be considered having the same Kelvin value. The color variance becomes even greater with LED light sources.
For those who want to know more about color and really like graphs and formulas (not me), check out the CIE 1931 chromaticity diagram, black body locus, MacAdam ellipse.
If you've installed one before, you know they're pretty much plug & play and it's hard to go wrong, so this isn't a huge deal, but the Morimoto kit was nicely packaged and very well labeled as to what went where. Both kits have plastic mesh wrapped cables, so that was pretty comparable. A big difference though is the relay if you choose to use it. The Xenon depot kit has a separate relay for each bulb/ballast, whereas the Morimoto kit had both relays mounted to a bracket and with one relay with long cords and one with shorts cords (since it will be mounted near the battery on the driver's side), so attention to detail like that was nice to see. I also prefer the Morimoto 4500k bulbs since as I mentioned above they where much whiter than my 5000k kit. Makes me wish I spent the extra $ on my Xenon Depot kit for the 4300k Phillips bulbs.
H.Sikina
